Battery cable size
rnkugel
First Name: Reuben
Last Name: Kugel
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Battery cable size
Post by rnkugel » Mon Apr 15, 2019 11:15 am
I have read to run 1 gauge wire for my 6 volt system. However, 1 gauge is tough to find locally. I can find 2 gauge easy enough. Is anyone running 2 gauge? How does it work for you? I have been running 4 gauge, but the starter still lacks. The starter has been rebuilt. Thanks
1915 Touring
1926 RAJO Speedster
Re: Battery cable size
Post by Steve Jelf » Mon Apr 15, 2019 11:19 am
Have you tried a welding supply?
jagiven
First Name: Jason
Last Name: Given
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Post by jagiven » Mon Apr 15, 2019 11:36 am
X2 on the welding supply shop, my local shop even puts the ends on form me.
My T, struggled with starting until, I replaced the grounding cable, and installing star washers to get a better bite between the various frame members to ensure a good ground all the way back to the battery.
Post by Mark Gregush » Mon Apr 15, 2019 11:39 am
0 or 00 is what I use. Most good parts stores (like NAPA) might have it in stock or order the cables from the parts suppliers.
Post by Scott_Conger » Mon Apr 15, 2019 11:51 am
1/0 is correct
2/0 is insurance
4 ga is for emergency heat during cold weather.
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Mon Apr 15, 2019 11:52 am
I just put in brand new 2 AWG and cleaned up the area where the ground goes to the frame on my 26 Touring. Works fine for me so far.
Post by Mark Gregush » Mon Apr 15, 2019 11:58 am
"4 ga is for emergency heat during cold weather." :lol:
