Looking for drag link information.
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Fri Jul 22, 2022 8:33 pm
What are the differences in Model T drag links? I understand that some have riveted ends while others are forged. What years used what links?
Craig
Re: Looking for drag link information.
Post by TRDxB2 » Fri Jul 22, 2022 10:11 pm
From a previous discussion
Post by Allan » Sat Jul 23, 2022 8:02 am
I addition to the above chart, the ends on the earlier ones were of a fine thread. Then they were changed to one end being fixed and the other on a coarse thread. Then came the riveted and brazed on ends.
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Jul 23, 2022 12:02 pm
Allan, I have seen coarse threaded drag links threaded on both ends. I've never seen one threaded on one end only. Please elaborate.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Sat Jul 23, 2022 3:09 pm
I have a drag link here at the house that is forged on both ends. Craig
Post by Scott_Conger » Sat Jul 23, 2022 3:47 pm
'09-'10: Fine threads
'11-'12: Coarse threads
July '12: pinned at different angles
Nov '12: pinned at same angle
Jan '14 - on: pinned and brazed
Post by Allan » Sat Jul 23, 2022 9:51 pm
Richard, the one I found when building my 1912 chocolate van had just one end threaded. It took till 2010 at Chickasha for me to get a good threaded end, from the fellow who makes the reproductions for the vendors. I ran the car for 15 years with a one piece riveted end 1913 item until I got the correct one.
Double ended threaded rods were likely easier to make initially. Once they could forge one end on the rod, a single threaded end could be used to get the angles between the two right. The next step obviously was to forge both ends at the correct angle and leave out all the machining, riveting and bronzing.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Sun Jul 24, 2022 12:17 pm
What year did forging both ends start? Craig
Post by Allan » Sun Jul 24, 2022 7:32 pm
My guess is somewhere between 1913 and 1915.
Post by Scott_Conger » Sun Jul 24, 2022 8:08 pm
Forged drag links began in July 1916. Existing stock of old drag links from other suppliers were used concurrently until May 1917 upon which FORD forged drag links were used exclusively.
