Identification Markings
Bryant
Topic author - Posts: 1184
- First Name: Bryant
- Last Name: Shafer
There seems to be a lot of identification markings all over the model T. What they all mean can be mysterious. Maybe someone will know? Post them if you’ve got them. while wire brushing my frame down today I found this marking under the scale. I can see the letter M Then maybe a B or R and what might be a C or G. Any ideas? Its on the rear cross member drivers side right at the body mount hole. 1926 frame
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Bryant
- Last Name: Shafer
Re: Identification Markings
Thanks that was very helpful
Different steel mills roll their I D marks in the product they produce. It may be just one of those.
I can't find previous discussions on this. These are the marks I am familiar with. I know A.O. Smith made frames early for Ford but others did later.
maybe someone else can remember.
There is a bunch of forging cartouches in the Ford Service Bulletins.
Some of the spring leaves on my 21 T has Carnegie randomly on the leaves. It’s faint but there.
The spring markings are very interesting too. Here are some I found.
and this 1914 date:
http://www.mtfca.com/discus/messages/17 ... 1321904484
I know we have discussed them before too, but where?
Bryant
- Last Name: Shafer
Are the service bulletins on the MTFCA site somewhere?
Bryant
- Last Name: Shafer
Rich, I like the little flag markings
I don't believe so Bryant - there's copied repro available at the vendors.
The pennant has MSC in the legend. That stands for Michigan Stamping Company, a supplier of later Ford frames.
The other major frame supplier was Parrish & Bingham, typical marking is P&B in a circle.
Service Bulletins can be read on the Model T Ford International site, under Technical Library on the homepage ModelT.org
Here is the listings of neat info on the Ford from that library.
http://www.cimorelli.com/mtdl/mtdl_year_title_list.htm
Thanks Dan. It is good to get answers like that.
Bryant
- Last Name: Shafer
Yes thank you Dan! I will be lost in that pile of info for days
here’s another hieroglyphic. Passenger side frame rail about the area of the carburetor. Possible assembly line guide?
Chuck Regan
- First Name: Chuck
- Last Name: Regan
Mark Nunn
- Last Name: Nunn
Bryant, Service bulletins are also on Cimorelli's website.
http://www.cimorelli.com/mtdl/service_b ... efault.htm
Been Here Before
- First Name: George John
- Last Name: Drobnock
A trade make is a trademark....
Bryant
- Last Name: Shafer
Then there’s this one which I would love to find out! Owner from long ago?
