Spark advance curve
FULLBORE
Last Name: Coats
Spark advance curve
Post by FULLBORE » Fri Sep 09, 2022 9:17 am
Good day everyone
Im looking for a dyno spark advance curve for model Ts
That would be a graph with spark on the vertical axis and rpm on the horizontal axis at maximum torque.
Re: Spark advance curve
Post by TXGOAT2 » Fri Sep 09, 2022 10:11 am
Is your engine and ignition system stock? If not, how is it modified? Correct spark timing in any particular instance depends on a number of factors. Stock torque maximum is around 900 RPM. A stock T engine can take a good bit of advance at that speed using pump gasoline.
