Bending Bendix washers
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Fri Sep 30, 2022 6:53 pm
Concerning bendix spring bolt washers. Does it matter where the tab that bends down rests? Should it touch the outer surface of the bendix spring or should it be down in "the gap" and the end of the spring?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Tmooreheadf
Last Name: Moorehead
Re: Bending Bendix washers
Post by Tmooreheadf » Fri Sep 30, 2022 9:01 pm
I always put mine in the gap!
Post by TRDxB2 » Fri Sep 30, 2022 9:35 pm
like they say in the gap
https://www.mtfca.com/discus/messages/5 ... 1461451254
Dan Treace, North FL on Saturday, April 23, 2016 - 12:57 pm:
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Sep 30, 2022 9:44 pm
The other tab of the lock washer has to be bent to match one of the flats of the bolt
tom_strickling
Post by tom_strickling » Fri Sep 30, 2022 9:50 pm
NICE photo Thanks Frank and everyone else
tom_strickling
Post by tom_strickling » Fri Sep 30, 2022 9:51 pm
And DAN for the original photo
Post by Mark Gregush » Sat Oct 01, 2022 2:12 am
For the tab that is bent up, I get mine just started bending before installing. Makes it easier to bend rest of way up after installing. The new ones are hard as heck and is why they should never if you can help it, reuse.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Oct 02, 2022 7:24 am
I always bend the other tab up a little bit, the bend it the rest of the way with a large pair of water pump pliers.
Other directions have noted the starter shaft can be bent by hitting that tab with a hammer to compete the bend.
