For Sale: Small Drum Bennett Brakes, Equalizer, & Pedal
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Mon Oct 10, 2022 8:42 pm
Here is a set of small drum Bennett outside accessory brakes, equalizer, and pedal.
The brakes have some wear on some of the parts. There were no linings on them when I got them. One brake is missing a small bracket and spring. The bracket is just a piece of flat steel bent on a 90 with two holes drilled in it so it should be easy to make. The spring should be easy to find at a good hardware store.
The equalizer is a Bennett and looks to be in good shape.
The pedal is a Rocky Mountain pedal. It has some ugly welds that should be cleaned up and redone.
Asking $300 plus shipping for everything. Please send me an email (not a private message). My email address can be found by clicking on my profile.
Ed Fuller
First Name: Ed
Last Name: Fuller
Re: For Sale: Small Drum Bennett Brakes, Equalizer, & Pedal
Post by Ed Fuller » Mon Oct 10, 2022 8:48 pm
More pictures
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Mon Oct 10, 2022 8:49 pm
Last picture
LuckyStrike1917
First Name: Jeron
Last Name: Takacs
* REQUIRED* Type and Year of Model Ts owned: 1919 Touring and a 1924 Coupe (all original)
Post by LuckyStrike1917 » Tue Oct 11, 2022 12:33 pm
I’m interested in these!
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Tue Oct 11, 2022 3:56 pm
Brakes are sold.
Thanks MTFCA!
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Oct 11, 2022 7:37 pm
The weld on the pedal is because someone welded a Ford brake cam onto the pedal. RM pedals had no brake cam on them.
