Exhaust manifold threads
Bill Anziani
Topic author - Posts: 246
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Looking for the size and thread count on late model exhaust manifolds. Also any sources for the appropiate die
Thanks in advance
Thanks in advance
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Re: Exhaust manifold threads
1-7/8 x 16 tpi.
- Last Name: Tannehill
- Board Member Since: 2002
Here's a die for $42.00. I bought one a while back. Pretty nice quality but took a while to arrive from China. I had to break my rule of not buying from Chinese sellers, which was hard pill for me to swallow.
https://www.ebay.com/itm/233249148019?h ... R4r19L6GYQ
The last time I saw one of the new exhaust manifolds it was the 25-27 style. If you want the earlier type it may have to be an original.
ModelTWoods
- First Name: Terry
- Last Name: Woods
A friend of mine, who also participates in this thread, had a manifold with unsalvageable threads that he was desperate to save. He took it to a machinist who cut off the damaged threaded end and then made a new end with more common coarse threads and welded the end to the manifold. Then the machinist made a new nut (from steel) with threads to match the new threads on the manifold. I'm sure he had a manifold worth its weight in gold by the time all was said and done, but with the nut screwed on, you can't tell its not original.
If you can deal with the welding aspect, a common pipe union could be adapted for connecting header pipe and manifold. Welding might be avoided by inserting a pipe nipple or short length of exhaust pipe in the manifold outlet and securing it with a bolt.
I bought a new one for my 21 Touring. Worked fine for me.
Bill Anziani
- First Name: Bill
Thank you to all that responded. I do greatly appreciate it
