Spring perch for what?????
elliott1936
Last Name: Elliott
Post by elliott1936 » Fri Nov 04, 2022 5:13 pm
Two sets of spring perches for an unknown car. I hope the someone can identify these items. I found in my model t stuff. If anyone can use them let me know. The look to be nos. The spring shackler length is 1 3/4" on both sets The hole size on the longer set is 3/4" The hole size on the shorter set is 5/8"
Last Name: Wrenn
Re: Spring perch for what?????
Post by TWrenn » Fri Nov 04, 2022 5:19 pm
Cute little things ain't they!?! :lol:
Last Name: Hjortnaes
Post by DHort » Fri Nov 04, 2022 6:51 pm
Looks like 26-27 rear perches.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Nov 04, 2022 6:55 pm
Yup, I agree 👍 Dave.
Post by speedytinc » Fri Nov 04, 2022 7:02 pm
They are not 26-7.
Moxie26
Post by Moxie26 » Fri Nov 04, 2022 7:12 pm
.... Can't stand the suspense, what car is it from Speedy John ???
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Fri Nov 04, 2022 8:11 pm
I don’t know for sure what car they are from. But on a 1926-27 T rear axel they look like they would lower or lift the rear almost one inch. So they may have been for a roadster pickup with a extra leaf spring. On a speedster to get a little lower used with one less leaf.
Post by John kuehn » Fri Nov 04, 2022 8:22 pm
If those are Ford perches there should be a T part number on them. You can barely see something on them but it’s not a clear shot where the supposed no. might be. I was thinking they were the earlier perches but not quite.
Post by RajoRacer » Fri Nov 04, 2022 9:20 pm
I have most all Ford parts books - not a Model T part.
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Post by Tim Moore » Fri Nov 04, 2022 10:42 pm
Could be replacement perches that went with an accessory shock system so the chassis stayed at Ford standard.
Tim Moore
elliott1936
Last Name: Elliott
Post by elliott1936 » Sat Nov 05, 2022 1:44 pm
On the longer perch there is a G DUC and a number3034 If that will help. They look like the could be 26/27 replacements Tom
Post by speedytinc » Sat Nov 05, 2022 2:29 pm
Tim Moore
This was my first thought also.
Purely speculation. I have not seen these in any of my accessory books.
The shorter version could be used to raise the back end up(26-7) to compensate for a weak spring, or heavy loads such as a calf, goats or a mother-in-law.
Reversing down would cause the spring to ride the axle tubes. So thats a no.
Could be part of a lowering system for a racer to hang the spring in front of the axle & tied to the radius rods.
Could be for one of any number of other period automobiles. If so, someone will recognize them.
Post by TRDxB2 » Sat Nov 05, 2022 3:40 pm
If the Model T Front spring is 1-1/2" wide & the rear 2" wide how could these be used on a Model T, accessory shock or not?
Post by Jerry VanOoteghem » Sat Nov 05, 2022 4:58 pm
You know, not every car back then was a Model T.... ;) :)
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Nov 06, 2022 1:57 pm
Hi Tom,
What would you take for them?
elliott1936
Last Name: Elliott
Post by elliott1936 » Sun Nov 06, 2022 2:09 pm
Creig:
I would take $40.00 For the pair plus postage which will go into a small flat rate box at $ 9.85. These look to be New Old Stock. Tom
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Sun Nov 06, 2022 8:34 pm
Looks like an old hot rod component made by "PSI". They made a lot of "ductal" iron suspension pieces.
