Pan Replacement
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Pan Replacement
Post by frontyboy » Mon Dec 05, 2022 11:18 pm
Want to change the pan on my '14 roadster. I have a 4 dip 26/27 pan to use. Will I have any issues with the exchange?
frontyboy.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Pan Replacement
Post by Dan McEachern » Mon Dec 05, 2022 11:45 pm
No- it will interchange with any 3 dip pan with no issues. Just don't let Larry Smith see it! Paint it black so it does not show................. :shock:
Re: Pan Replacement
Post by TRDxB2 » Mon Dec 05, 2022 11:48 pm
In reading about pan's sound like the 3 dip pan is stronger than the 4 dip
Since the '26 has a wider brake drum then wouldn't the pan and then the hogs head as well. And then pedal locations. If you don't have to replace the hogs head then as Dan said it will work... https://mtfca.com/phpBB3/viewtopic.php?t=12749
Last Name: van Ekeren
Re: Pan Replacement
Post by Kerry » Tue Dec 06, 2022 1:33 am
I had a 4 dipper and a narrow nose pan that both had issues, so a cut and shut and now I have a 4 dipper with a narrow nose on my 16.
