Spinning your wheels
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Jan 20, 2023 10:43 am
This one might be an '09 ? Flat belt off the rear wheel is powering something in that barn. I don't think I've ever seen a horn bulb mount like that one. Looks practical !
Get a horse !
Last Name: Tannehill
Board Member Since: 2002
Re: Spinning your wheels
Post by JTT3 » Fri Jan 20, 2023 10:50 am
I’d say late 9 based on the 2 bolt front body mount, tulip seats front & back, butterfly rear fender brackets are under the skirt not through the fender apron & tapered spokes. I can’t identify the side lights to big for JB 60’s & tiers are different, oil fonts are different. I’m relatively positive that the headlights are JB.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Jan 20, 2023 11:06 am
Looks like it may have the ford script with wings on the radiator, Piquette manufactured car?
Last Name: Wrenn
Post by TWrenn » Fri Jan 20, 2023 11:15 am
Running boards look '09 as does the headlamp. Is that some sort of animal curled up in the driver's area? Too blurry to tell for sure.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Jan 20, 2023 12:20 pm
Looks like a pup in the driver's seat. He moved!
Get a horse !
Post by Rich Eagle » Fri Jan 20, 2023 12:27 pm
I think the Tourabout was not offered until July 1910 so it wouldn't be called a '09.
Correct me if I'm wrong.
The license plate looks like a 1912 Ohio if I am seeing it right.
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Fri Jan 20, 2023 2:14 pm
Like you said Tim, 09, based on 2 hole front body mounts, no reinforcing plate in radiator, and scalloped cut rear apron. Dog ID a bit tougher.
Last Name: van Ekeren
Post by Kerry » Fri Jan 20, 2023 3:40 pm
The Saturday evening post, August 1909, one of the 6 body styles for Fords.
Post by Rich Eagle » Fri Jan 20, 2023 3:55 pm
I appreciate the picture, Kerry. According to the model T Ford encyclopedia, the "Tourabout shown in Ford Times but not produced until July, and then called 1910 cars."
"MODEL YEAR DATES: October 1908 to July 31, 1909. (Ford called the cars built after July 31 1910 models."
So, I was wrong about it being July 1910 but rather July 1909.
Sorry.
