How to get your speedster to 90 mph.
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Post by Petrah Phyre » Thu Feb 16, 2023 2:25 pm
Strap it to an eastbound trailer on I90 in Montana. Finally getting it moved to it's new home.
Re: How to get your speedster to 90 mph.
Post by speedytinc » Thu Feb 16, 2023 2:56 pm
Try jumping the Grand Canyon.
I think you will exceed 90 before you hit the bottom, if you get a good run @ it.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Feb 16, 2023 3:20 pm
This car is certainly capable of that on the highway. I personally only had it to 75, but the guy I sold it to got a ticket at 92 and he had backed off!!
Post by Jerry VanOoteghem » Thu Feb 16, 2023 3:46 pm
Sean,
Show us more of it!!!
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Thu Feb 16, 2023 5:07 pm
When I first knew it was mine.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Thu Feb 16, 2023 5:08 pm
Before the trailer load up.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Thu Feb 16, 2023 5:10 pm
I will be posting more as it gets to be road worthy, but that may be a time down the road. New business to get established.
Post by Jerry VanOoteghem » Thu Feb 16, 2023 5:48 pm
Very cool! Looks as if it has a lot of gear shifts?
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Thu Feb 16, 2023 7:15 pm
It has a Starr Planator. Found that out on this forum. Thought I had a Ruckstell until I was schooled.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Feb 16, 2023 10:56 pm
The Ash wire wheels are a good start at making the car stable at higher speeds… but I’m afraid with just a low head for speed equipment yur gonna need to stick with the trailer😉
Post by TXGOAT2 » Fri Feb 17, 2023 10:07 am
90 MPH? No problem! Add a supercharger and propane fuel system, a Marvel Mystery Oil injector, a Scat crank, rods, mains, modern flywheel, oil pump, forged pistons and under/direct/over Warford with a '48 u-joint. Don't forget the water pump, radial tires, drag chute, Plum Crazy paint job, and waterless coolant!
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Feb 17, 2023 10:42 am
And good health insurance!
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Sat Feb 18, 2023 3:21 am
The guy who sold it to my father in-law told him it would do 70 with the Planitor in direct and that it was installed backwards for an overdrive to 110. :lol:
I think someone's leg was being pulled.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Sat Feb 18, 2023 3:22 am
Pah! Did Henry have health insurance?
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Sat Feb 18, 2023 3:25 am
Was missing one hubcap. Found two Ash wheels/one cap on TBay. Shipping from Murdo SD cost me $50+. One year later I moved to Custer SD. Oh well. Still $ well spent.
