For Sale: 5-Z-287 Genuine Ford Rear Wheel Hub Puller for Model Ts with wood spoked wheel. This example is a bit different because the name “Ford” is embossed on the puller body rather than sunk in which is more commonly found. The puller is in excellent condition, almost like new. The internal threads which engage the hub cap threads are in perfect condition. The pressure screw is also in very good condition. The square corners are sharp, not rounded over. When properly used, this puller will remove the most stubborn rear wheels. $85 plus shipping.
FS: 5-Z-287 Genuine Ford Rear Wheel Puller
Re: FS: 5-Z-287 Genuine Ford Rear Wheel Puller
email sent
LOCParts
Topic author - Posts: 56
- First Name: Langs
- Last Name: OldCarParts
The 5-Z-287 has been spoken for.
Thanks MTFCA!
Thanks MTFCA!
