Ruckstell Question
Plankhill
Topic author - Posts: 140
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Ruckstell Question
Is the P139 thrust plate interchangeable between the Hal Scott and the Ruchstell? The Hall Scott internal gear is shorter than the Ruckstell.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Ruckstell Question
That's a question for Richard Gould.
- Last Name: Tannehill
- Board Member Since: 2002
Dan didn’t you post a picture one time with a scoop on the P159 ring gear support housing that you added for better internal lubrication? Was it brazed on or pinned? Best John
All passenger car parts are interchangeable, whether Hall Scott or Eaton.
RGould1910
- Last Name: Gould
The only piece interchangeable between a Ruckstell and Perfecto is the large ball bearing.
