John Reagan - technical library
SteveBoothroyd
First Name: Steven
Last Name: Boothroyd
* REQUIRED* Type and Year of Model Ts owned: US built 1922 touring
Post by SteveBoothroyd » Thu Apr 13, 2023 4:32 pm
Does anyone know what happened to John Reagans technical library?
I've been out of the loop for quite a while.
Regards,
Steve Boothroyd
Last Name: Hjortnaes
Re: John Reagan - technical library
Post by DHort » Thu Apr 13, 2023 9:21 pm
Try John Regan, not Reagan.
Post by TRDxB2 » Thu Apr 13, 2023 11:14 pm
Regards,
Steve Boothroyd
Not sure how long you have been "out of the loop". But in 2018 Birdhaven bought FunProjects and the FunProjects site expired a short time later. Birdhaven recently bought the new inventory & machinery from Bob's Antique Auto Parts in Rockford Il (Bob is still in business selling original parts).
Thankfully someone created a WEBPAGE to save old webpages https://web.archive.org/web/20201203202 ... jects.com/
Unfortunately they don't connect all the links. But its best to capture the source data and save in t he forum. Perhaps we can add to a forum page like Vowel art I'm going to download all the files, 50+, (PDF's) Techinfo and Instructions. I
Here are some
ButterTubRack.pdf
(31.54 KiB) Downloaded 155 times
WheelpressA2.pdf
(105.02 KiB) Downloaded 152 times
Speedomnt.pdf
(24.17 KiB) Downloaded 127 times
Post by TRDxB2 » Thu Apr 13, 2023 11:28 pm
Some more..........................................
the model t ignition coil - part 1.pdf
(2.57 MiB) Downloaded 145 times
the model t ignition coil - part 2.pdf
(2.46 MiB) Downloaded 117 times
the model t ignition coil - part 3.pdf
(3.8 MiB) Downloaded 117 times
Rruckstell Axle Brochure.pdf
(1.22 MiB) Downloaded 122 times
Operating Instructions Model MT-1.pdf
(148.5 KiB) Downloaded 131 times
Post by TRDxB2 » Thu Apr 13, 2023 11:35 pm
Excessive Crankshaft Endplay Repair.pdf
(683.51 KiB) Downloaded 139 times
Model T Frame (early).pdf
(36.37 KiB) Downloaded 110 times
Installation Instructions Model - HSBCK1.pdf
(16.02 KiB) Downloaded 99 times
Model t ignition system-final artiticle.pdf
(388.82 KiB) Downloaded 112 times
More on Spark Timing.pdf
(1023.86 KiB) Downloaded 115 times
Post by TRDxB2 » Thu Apr 13, 2023 11:50 pm
Brass Magneto Post (1909-1917) 3260.PDF
(25.08 KiB) Downloaded 109 times
Dash Shield (1909-1923) & Guide (1909-1912).PDF
(17.38 KiB) Downloaded 126 times
Fanbelt tension Spring (1909-1910) 3965.PDF
(9.97 KiB) Downloaded 83 times
Running Board Truss Rod - 4816.PDF
(15.66 KiB) Downloaded 112 times
Instructions -Strobe Spark- Coil Tester CT-1 (60Hz Version).pdf
(602.01 KiB) Downloaded 112 times
Post by TRDxB2 » Fri Apr 14, 2023 12:06 am
Installation Instructions 5055R-6V S5055R-6V.pdf
(42.53 KiB) Downloaded 108 times
Installation Intructions 5055R-8V S5055R-8V.PDF
(53.32 KiB) Downloaded 81 times
Installation Instructions 5055R-12V S5055R-12V.pdf
(42.66 KiB) Downloaded 90 times
Installation Instructions Voltmeter 5016-6V.pdf
(34.54 KiB) Downloaded 92 times
Installation Instructions Voltmeter 5016-12V.pdf
(34.52 KiB) Downloaded 88 times
Post by TRDxB2 » Fri Apr 14, 2023 12:45 am
Instructions Model 5007KW Clocks.pdf
(16.32 KiB) Downloaded 104 times
Installation Instructions Models 3260E1, 3260E2, 3260E3.PDF
(36.57 KiB) Downloaded 92 times
Installation Instructions Adjustable Bearing Spool Models - 2587-ADJ, 2587E1-ADJ.PDF
(125.18 KiB) Downloaded 101 times
Installation Instructions Adjustable Bearing Spool Models - 2587, 2587E1.PDF
(51.83 KiB) Downloaded 99 times
T5426 Dash Molding.pdf
(29.2 KiB) Downloaded 99 times
Post by TRDxB2 » Fri Apr 14, 2023 12:47 am
Floor Plan Trim Plates (1909-1917) 3630.PDF
(11.81 KiB) Downloaded 103 times
Lamp Bracket on Dash(1909-1914) 3655.PDF
(10.75 KiB) Downloaded 91 times
Instructions Model CT-2 Coil Beeper.pdf
(16.42 KiB) Downloaded 98 times
Instructions - Coil Units and Magneto Test Stand - FORD Manual.pdf
(2.91 MiB) Downloaded 95 times
Installation Instructions Model T12CK1.PDF
(48.3 KiB) Downloaded 88 times
Post by TRDxB2 » Fri Apr 14, 2023 12:50 am
Motorst-90110.pdf
(38 KiB) Downloaded 87 times
Accurate Spark Timing.pdf
(742.74 KiB) Downloaded 128 times
Installation Instructions Battery Horn 6V- Models 6432, 6432E2.PDF
(38.97 KiB) Downloaded 96 times
Installation Instructions Battery Horn 12V- Models 6432-12V, 6432E2-12V.PDF
(38.99 KiB) Downloaded 85 times
Installation Instructions rewood Models 5000-5001RK.pdf
(128.28 KiB) Downloaded 99 times
Post by TRDxB2 » Fri Apr 14, 2023 12:56 am
Archifacts by John Regan.pdf
(248.54 KiB) Downloaded 96 times
Model A Voltage Regulators
Instructions Model A Voltgae Regulator 6V NegGrnd & 12V Battery 10505RN12.pdf
(24.39 KiB) Downloaded 91 times
Instructions Model A Voltage Regulator 6V PosGrnd Models 10505R, S1050R.pdf
(24.18 KiB) Downloaded 78 times
Instructions Model A Voltage Regulator 6V PosGrnd & 12V battery Model 10505R12.pdf
(24.15 KiB) Downloaded 68 times
Instructions Model A Voltage Regulator 6V PosGrnd & 8V Battery Model 10505R8.pdf
(24.08 KiB) Downloaded 83 times
Post by TRDxB2 » Fri Apr 14, 2023 2:13 am
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Apr 14, 2023 7:03 am
John had a very good long term friend, Ron Patterson, that still rebuilds coils.
Until recent years, they were always together at Hershey and other events, like large swap meets.
Ron had a rather extensive library and downsized when he moved to a new location.
Ron donated all his library to the MTFCA Museum in Richmond, Indiana and they are available for research there.
I talked with Ron recently and he said he had not heard from John for some time now.
Ron does wish that John would call him again and catch up on life and other new activities.
Post by John kuehn » Fri Apr 14, 2023 10:18 am
This great information should be a permanent part of the MTFCA resources page. There are also others who have gathered lots of T information that’s really useful.
Maybe the resources page could have these as contributors.
Post by Steve Jelf » Fri Apr 14, 2023 11:16 am
I would add the Cimorelli Model T library.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Fri Apr 14, 2023 1:39 pm
WOW lots of very importanr information. I may download all and put on disc or tumb drive.
Post by John kuehn » Fri Apr 14, 2023 1:59 pm
It would sure benefit the older T members and greatly benefit the younger. It makes good sense to me. At the very least the website addresses could be listed all in one place. Wow that seems simple.
SteveBoothroyd
First Name: Steven
Post by SteveBoothroyd » Fri Apr 14, 2023 2:28 pm
Thanks everyone for your input; I really appreciate the information John created for the hobby.
Regards,
Steve Boothroyd
Sidney, B.C.
Canada
SteveD
First Name: steven
Last Name: davidson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by SteveD » Wed Apr 19, 2023 2:45 pm
Thanks for the links. I need to build that wheel press. I just sent the PDF to my office manager to print for me, and he just came back with full size roll up prints! I'll be able to hang it on the wall while I build it!
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed Apr 19, 2023 4:41 pm
It would seem the Museum would preserve these files or perhaps store them on site here for all to use?
Post by DHort » Thu Apr 20, 2023 9:56 pm
I wish they could preserve all of Vince Iacinno's video's too.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sat Apr 22, 2023 12:43 pm
Ya, Those videos that Vince made were priceless when I installed one of his tops. I do have a set just ion case anyone reads this and is planning an upholstery job
1912 Torpedo Roadster
Post by Steve Jelf » Sat Apr 22, 2023 1:19 pm
I do have a set just in case anyone reads this and is planning an upholstery job.
Take good care of them. When I inquired a few years ago all the copies had been sold and the masters were lost.
Post by DHort » Sat Apr 22, 2023 11:23 pm
I have some of those copies. His wife still has the masters. No one wants to purchase them from her.
JohnSuar
Last Name: Suarez
Post by JohnSuar » Mon Jun 26, 2023 7:23 am
I will download these files as well. Thank you. I remembered that I had already been advised to use this technical library but had forgotten about it. I need assignment help for a technical project, and it looks like I will be able to find a lot of useful info here. I'm also going to use this online source https://essays.edubirdie.com/assignment-help to secure a written part of my project and get a good result. Now I'm going to explore John Reagan library more.
