Stamped logo
First Name: craig
Last Name: leach
Stamped logo
Post by Craig Leach » Tue Apr 18, 2023 9:29 pm
I was thinking some one asked about this logo a while back. Anyone have knowlege of it. I found it on a small brake drum.
stamped logo.jpg (26.27 KiB) Viewed 1570 times
Thanks .
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: Stamped logo
Post by BUSHMIKE » Wed Apr 19, 2023 8:30 am
Craig,
Was it me you are thinking of? I asked about this logo on my TT frame a while back.
First Name: craig
Last Name: leach
Re: Stamped logo
Post by Craig Leach » Wed Apr 19, 2023 10:20 am
Hi Mike,
It could have been, but was thinking it was the same logo?? Thanks.
Re: Stamped logo
Post by DanTreace » Wed Apr 19, 2023 12:52 pm
The frame marking is Parrish and Bingham. Ford supplier.
That other mark appears as Transue Williams, another supplier.
First Name: craig
Last Name: leach
Re: Stamped logo
Post by Craig Leach » Wed Apr 19, 2023 1:15 pm
Thanks Dan,
Re: Stamped logo
Post by Allan » Wed Apr 19, 2023 8:05 pm
On our Canadian sourced cars the Transue Williams mark appears as a capital T superimposed over the W. This mark i have only found on forged parts, an so it is raised.
Re: Stamped logo
Post by DanTreace » Wed Apr 19, 2023 9:22 pm
I was thinking some one asked about this logo a while back. Anyone have knowlege of it. I found it on a small brake drum.stamped logo.jpg
Thanks .
May not be Transue Williams. That same mark is seen on tools too, like this hub cap wrench, since your rear hub brake drum is a steel stamping, like the flat hub cap wrench, could be this mark in a triangle is Weston Mott. They were a stamping concern.
ford mark. weston.jpg (26.47 KiB) Viewed 1227 times
First Name: craig
Last Name: leach
Re: Stamped logo
Post by Craig Leach » Thu Apr 20, 2023 9:54 am
Thanks guys,
Looks like it most likely is a O.E.M. part. I thought it might be a after market because it doesn't look like it has any wear to speak of.
