Wanted: Rader Distributor Body Only !
Post by RajoRacer » Fri May 05, 2023 5:19 pm
Any chance of an "orphan" distributor housing for a Bill Rader distributor hanging on a wall or nail in somebody's garage ??? Friend brought in a rebuilt engine all covered & wrapped as it made a 1000 mile road trip and "someone" pushed on the front of the engine not knowing what was under the package ! Needless to say, the little arm that grabs the original timer clamp bolt got broken clean off ! I'd rather replace than have it welded.
Drop me a note through the Forum, please.
Re: Wanted: Rader Distributor Body Only !
Post by Mark Gregush » Fri May 05, 2023 10:27 pm
Maybe post a photo of it, might jog someone's memory.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat May 06, 2023 11:41 am
Hi Steve,
Are you talking about the arm that bolts the drive to the engine through a generator bolt?
Post by RajoRacer » Sat May 06, 2023 1:00 pm
Yes - that broke clean off ! I'll get a photo posted after the T Club meeting today.
Post by RajoRacer » Sat May 06, 2023 6:29 pm
Here's what a Rader distributor looks like. I guess I might be able to "swing" it farther left if I don't hit the oil fill cap !
First Name: craig
Last Name: leach
Post by Craig Leach » Sun May 07, 2023 1:09 am
Hi Steve,
The reeder distributor on my speedster I did pull all the way down into the notch and yes it will be in the way. Not so much the cap but
trying to pour oil in to the fill. I put a elbow with a 90* piece that sweeps up at 45* for a fill out of a ( this is going to hurt ) heat riser tube
of a 1980s Chevy. Makes it a breeze to add oil but may have hood clearance issues if to long.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Sun May 07, 2023 10:00 am
Steve, just curious by why not re-weld the broken piece back onto the body? Is it because of the porosity, -or that you are afraid you wont be able to get the alloy clean enough??
Post by RajoRacer » Sun May 07, 2023 12:02 pm
My S.I.L.'s little brother is a "whiz-bang" aluminum welder - he could weld it but it's a 2+ hour ride there & back. It's never been installed so welding it should be O.K. I was never too keen on that arm arrangement on those distributors !
Post by Mark Gregush » Mon May 08, 2023 12:53 am
Could you mount a plate with a slot cut at the same arc?
