Voltage with Fun Projects VR
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Tue May 16, 2023 4:31 pm
Hi,
what is the expected voltage on a 6V model T equipped with the Fun Projects Voltage Regulator (VR) and engine running at some rpms well above idle?
Ford Model T 1914 Touring
Moxie26
Last Name: Jablonski
Re: Voltage with Fun Projects VR
Post by Moxie26 » Tue May 16, 2023 5:00 pm
7.2 to 7.4 vdc
dykker5502
First Name: Michael
Post by dykker5502 » Wed May 31, 2023 7:03 pm
Thx, that wasalso as expected, but I only see 6,3 volts. Better check the generator.....
Moxie26
Post by Moxie26 » Wed May 31, 2023 8:19 pm
The reading that you're getting refleects the charge on your battery and the load. Same reading with your headlights on ???
Post by Mark Gregush » Fri Jun 02, 2023 3:43 pm
If you are checking the generator output on the generator side of the cutout, it should be read in amperes not volts and set for around 4-6 amps at medium fast idle. As said, if checking the output/battery side, that would be the battery voltage, there is line voltage at all times on that side.
