When Ford built magneto coils, we're they coated with any sealer before or after mounting on the plate?
Also what type of fabric were they wrapped in and what would compare with it today?
We're mag coils sealed?
Topic author - Posts: 260
- First Name: Dennis
- Last Name: Brown
- Last Name: Tannehill
Re: We're mag coils sealed?
Info you may be interested in:
https://youtu.be/VTNQiabdZp4
Dennis_Brown wrote: ↑Thu Jun 08, 2023 10:49 pmWhen Ford built magneto coils, we're they coated with any sealer before or after mounting on the plate?
Here is the Ford spec on the insulating varnish, note the first sentence that described the assemblies were coated.
- Last Name: Bartsch
Cotton twill overwrap on each coil, and final assembly coated in shellac-based insulating varnish.
- Last Name: Patrick
Now a days, the coil wrappings are sealed with brushed on “Glyptal”, which was originally developed by Thomas Edison and his Company, GE to seal the wire windings of electric appliances such as fans and generators. It comes in clear and red. Since it is so tough and impervious to oil, many of us here have used it to coat the inside of our Model T crank cases and oil pans to prevent the buildup of sludge on the interior surfaces and to brighten the interior of the engine to improve the visibility inside the engine. Jim Patrick
