WTB 1911 Model T tools
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Mon Jul 03, 2023 12:43 pm
Want to buy the following tools for my 1911 tool kit; T 1917 Band Adjusting Wrench, T 1903 Pliers, and T 1387 Adjustable
Wrench. Please see pictures for description. Call 586-243-7202 or email astein.pls@gmail.com. AL
AdminJeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Re: WTB 1911 Model T tools
Post by AdminJeff » Mon Jul 03, 2023 10:39 pm
I have these:
Assistant WebSite Admin
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
Post by Allan » Tue Jul 04, 2023 7:26 am
Alan, I have never seen a pair of pliers with the script on the jaws. On those I have found it has always been on the handles. Some of the scripts are raised, others have the background stamped down. is the position of the script an indication of the likely date of production?
BigAl
First Name: Alan
Last Name: Stein
Post by BigAl » Thu Jul 13, 2023 12:17 pm
Still Looking! Using "The 1911 Model T Ford Tool Kit by Royce Peterson" as reference. If anyone has additional knowledge regarding what are the correct tools I would appreciate your input. Thank you
BigAl
First Name: Alan
Last Name: Stein
Post by BigAl » Sun Jul 16, 2023 11:47 am
Need Help to complete my tool kit! These tools must be out there somewhere. Call or email.
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Mon Jul 17, 2023 8:45 am
What year would this one be? If you look close the ford logo is on top of another Ford that was upside down. It's a raised Font too.
* REQUIRED* Type and Year of Model Ts owned: ‘12 open express,'23 cutoff, '27 touring
Post by DanTreace » Mon Jul 17, 2023 5:05 pm
Have a copy of the Record of Change for the T-1903. Interesting is that the 'screwdriver tip' was on the pliers prior to 1913, so the pliers likely had that tip on one handle for long time, even when the T-1902 screwdriver was part of the tool kit.
Details:
2-2-1913 'change screwdriver tip to 1/32" thick at end from 3/64"...specified length of bevel.'
12-19 1914 'specified trademark script indicated by arrow the location of same.' (don't have the early drawing to note where located)
10-11- 1920 ''change bevel of end of screwdriver tip to 7/8" from 3/8"...specified end to be hardened ....this change made to enable pliers to replace screwdriver in the tool kit...screwdrivers on hand to be used up.'
10-22- 1920 'specified Ford script to be placed inside handle'
7-9-1921 'changed length of handle with screwdriver from 6 1/2" to 6 3/4".'
6-1-1922 'specified part to be A1 indicating alternate design. specified Ford script to be placed on outside of handle.'
6-1-1922 'new alternate design'
1-19-1923 specified part to be T-1903-A2
bpresslylsmo
First Name: Bob
Last Name: Pressly
Post by bpresslylsmo » Tue Jul 18, 2023 10:28 pm
I have two examples of the early band adjusting wrench I would sell. One has been wire brushed and one has not.
Your choice $20+shipping
[image][/image]
Post by Allan » Wed Jul 19, 2023 4:38 am
That's the one Bob!
BigAl
First Name: Alan
Last Name: Stein
Post by BigAl » Thu Jul 20, 2023 12:41 pm
Found the T 1917 Band Adjusting Wrench, one down two to go. Still looking for the T 1903 Pliers and the T 1917 Adjustable Wrench as per my picture post. HELP, someone has these laying around unused. They will go to a good home.
