WTB: Steering Shaft
Scott C.
Last Name: Clements
WTB: Steering Shaft
Post by Scott C. » Mon Jul 03, 2023 10:05 pm
I am needing a good steering column shaft for my 26 Coupe. The vendors are all out of stock. Does anyone have a new one lying around or, a good used one that you are willing to sell? Or even a complete steering column with a good shaft.
Jeff Perkins
First Name: Jeff
Last Name: Perkins
Re: WTB: Steering Shaft
Post by Jeff Perkins » Tue Jul 04, 2023 9:08 am
I have a good used one + gears…..pm me to talk. Jeff P. in MN
1926 Model T Touring,
1948 Chrysler New Yorker,
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jul 05, 2023 12:51 pm
I sent you a PM.
Jeff Perkins
First Name: Jeff
Last Name: Perkins
Post by Jeff Perkins » Wed Jul 05, 2023 1:19 pm
Hi Scott,
I sent a PM yesterday and an email w/ pictures just now.
Thanks, Jeff P.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jul 05, 2023 4:14 pm
Still looking.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Wed Jul 05, 2023 5:05 pm
How do you determine if the shaft is for 26-27 and not 12-25?
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Wed Jul 05, 2023 5:07 pm
also show the difference of the franme bracket 26-27 from the 12-25.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jul 05, 2023 9:12 pm
The 26-27 is a 5 to 1 ratio. The top of the shaft where the gears and pins go should have a 5 stamped into it. The hole spacing is different than the earlier 4 to 1 type. I believe that all of the reproduction shafts are 5 to 1. The 26-27 column has a square mounting plate where if bolts to the cowl. Here are pictures form Lang's website of the 26-27 box. I am not sure of the difference. I think maybe it mounts at a different angle.
Post by RajoRacer » Wed Jul 05, 2023 10:47 pm
The earlier steering bracket is quite a bit different in design.
