New vs old gas shut off valves
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Thu Jan 11, 2024 8:41 pm
So i ordered 2 gas shut off valves that are the 90 degree that go by the carburetor from langs. Whats the difference betweed the old ones and new ones?
Moxie26
Last Name: Jablonski
Re: New vs old gas shut off valves
Post by Moxie26 » Thu Jan 11, 2024 8:58 pm
The. "old" one is activated by the sediment bowl lever, the new shutoff installed at the carb came after production ceased.
Post by Norman Kling » Thu Jan 11, 2024 9:02 pm
Main reason is to avoid crawling under the car to shut it off.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Thu Jan 11, 2024 9:50 pm
Austin about 4 feet and you don’t crawl under the car.
Last Name: Hatch
Post by Dan Hatch » Fri Jan 12, 2024 4:39 am
Guys: I think he is asking what is different between the old right angle carb mount cutoffs and the new right angle carb mounted cutoffs.
I have been told that the new ones have been known to leak. I have not used any new ones, just reporting what I have heard.
Post by Allan » Fri Jan 12, 2024 5:24 am
My "old" one not only leaked, it became very hard to turn off/on without pliers.
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Fri Jan 12, 2024 8:20 am
Are you talking about flat handle VS rounded handle, both fairly modern?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Last Name: Strange
Post by CudaMan » Fri Jan 12, 2024 9:12 am
My 1924 has the newer, "flat handle" valve. Once a month or so, I disassemble the valve and lubricate it with "EZ-turn", available from the vendors.
https://www.modeltford.com/item/2902LUB.aspx
George Mills
Last Name: Mills
Post by George Mills » Fri Jan 12, 2024 9:44 am
I know this is going to sound a bit unsafe, but it works for me.
Round handle, 90 degree valve. Works good for a while, then wants to stick and/or leak.
For the 'stick' on opening, a pull tension upwards while turning, case closed...works and does not stick.
For the leak on closing, when closed I give it a tap with a wrench, no leaks! Forget to tap? Get a puddle.
Someone above recently said to rebuild it with a sealing goo from time to time and that's probably the best solution...I've thought of a toothpaste lap...but I think that may make even more 'stick' if it isn't lubed?
Post by RajoRacer » Fri Jan 12, 2024 10:50 am
George has the correct procedure for both types of valves - simply lift up a smidge off the seat BEFORE turning then simply apply a bit of downward pressure - no leaks !
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Fri Jan 12, 2024 2:32 pm
I have always did the same procedure as George on all the "taper seat" type of valves. That includes the oil peacocks on the crankcase. I keep the pliers easy to find in the tool kit and use them to open or close the valves. After closing the valves just a light tap or two with the pliers to re-seat the taper, and never any leaks.
Post by Original Smith » Fri Jan 12, 2024 2:36 pm
I like the old design, because it really looked period correct. I'm lucky to have one on all of my cars.
Post by RajoRacer » Fri Jan 12, 2024 4:38 pm
I agree Larry - they appear to have been made like the original oil /radiator petcocks. The newer repro style has a shorter spring and a screw holding it together.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Jan 12, 2024 4:39 pm
Yes, this is what I mean. I have only been in the hobby a few years, and i heard on an earlier thread how they don't make.the old ones anymore, and they were apparently better than the onea they have now? I was asking since i dont have any experiences with the old design.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Jan 12, 2024 4:44 pm
This is what i ordered.
Post by RajoRacer » Fri Jan 12, 2024 5:46 pm
That style works just fine IF you take the time to lift the handle up just a smidge BEFORE turning. It's alot better than some of the cobbled up plumbing store hardware I've seen installed !
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Sat Jan 13, 2024 12:42 pm
I have a new one I purchased from Lang’s. I too found over time that it became more difficult to operate, to the point of using pliers to turn it. I took it apart thinking that debris might be causing the issue. What I found was after cleaning, it worked fine for a while then reverted back to almost impossible to turn. Upon the second or third disassembly I chose not to tighten the screw that secures the valve as tight as it would go. I think the spring tension against the screw holding it together is too much, pulling the taper valve too deep into the body. My solution was to back the screw off a bit. To keep it in place, I staked a couple of threads a bit to provide interference to the valve body. It has been working fine now for several months without leaking or becoming progressively difficult to use.
Scott
