Going through parts, found this swivel joint.
Doesn’t look like the ones from 1911 and up
Threads right on to a commutator rod.
Early swivel joint for commutator rod?
Re: Early swivel joint for commutator rod?
Or a throttle linkage on a RHD car.
GG Gregory
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
I’ve got a few of those, always thought they were odd.
Mark Chaffin
- Last Name: Chaffin
According to the Ford archives, two styles were used during production. One was a Ford designed part and the other produced by an outside source. The one shown is very similar to the outside source print.
Ron Patterson
The Ford part like that has 7/32 X 32 TPI on bith male and female ends.
Ron Patterson
Ron Patterson
Ron, is 7/32" equivalent to a certain wire gauge? I have found that spoke nipples from Wire wheels have the same thread as the T carb linkages and timer rods. I have used a section of one nipple as a locknut against swivel end on a carb linkage.
AKA 12-32 UNEF thread.
