12v Led Headlamp Bulb.
George Hand
Last Name: Hand
Post by George Hand » Thu Jan 25, 2024 3:09 pm
I have a 1925 homemade bodied pickup & for those using a Led headlamp bulbs, double filament & 12v, what generic part number are you using? I also have Model A style (Chinese) double filament tail lamps do you have a Led part # for those. TIA George
Novice
First Name: Jim
Last Name: Davis
Re: 12v Led Headlamp Bulb.
Post by Novice » Thu Jan 25, 2024 7:04 pm
This is what I use. Dual filament. Socket orientation does not effect operation like new and old incandescent bulbs some of which which have 180 degrees rotation on two base pins. Filaments should be horizontal when locked in headlight socket.
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Thu Jan 25, 2024 7:10 pm
The 12v LED Headlamp bulbs w/ adjustable base that Snyders sell , a little pricey but work very well, excellent lighting reach in front of vehicle.
John M
Oscoda,Michigan
George Hand
Last Name: Hand
Post by George Hand » Thu Jan 25, 2024 7:29 pm
Novice, Do the lamps you use have 2 different outputs? Do you also use the same bulb in the tail/stop lamps & now for the $64,000 question is there a generic part number?
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Post by greenacres36 » Thu Jan 25, 2024 10:25 pm
:) Snyder’s led lights. The way to go
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Thu Jan 25, 2024 11:38 pm
Regards,
George Hand
Last Name: Hand
Post by George Hand » Fri Jan 26, 2024 8:34 am
Thanks All, I can purchase some to see how they work. George
RVA23T
Last Name: C
Post by RVA23T » Fri Jan 26, 2024 12:44 pm
ba15d-60-smdt.jpg This is what I use. Dual filament. Socket orientation does not effect operation like new and old incandescent bulbs some of which which have 180 degrees rotation on two base pins. Filaments should be horizontal when locked in headlight socket.
I have use these and I like the light output BUT the front facing board of leds brakes lose and falls off from shaking and vibration, leaving the outer ring of leds and rendering the bulb useless.
The solder points are too brittle and do not flex enough in my T but YMMV
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Sun Jan 28, 2024 1:53 am
George. Yes they have two brightness levels. They are large headlights type bulbs and probably wouldn't fit in tail light housing and would be over kill if they did. They sell other led bulbs for tail lights. Ledlights.com has the best selection and prices. ba15d is the part number of the ones I bought. If vibration is a problem the wedge shaped 5-30 volt bulbs would probably be more durable but they are pricy and need headlight sockets to be correct orientation for focusing. Many model T headlight sockets have been replaced with incorrect ones. My 23 Truck has one correct and one wrong. But with ba15d it doesn't matter.
