Help ID my rear hub
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Help ID my rear hub
Post by csnailnrun » Fri Feb 09, 2024 9:24 pm
I wasn’t successful at finding any info online for “taped rear hub” via the MTFCA site.
Most likely operator inability to use the right phrases 😝
Thanks for any insight on this piece.
[image][/image]
Re: Help ID my rear axle and hub
Post by Jerry VanOoteghem » Fri Feb 09, 2024 9:28 pm
Not sure what you want to know. Looks like a typical T axle, although the taper ends a bit far from the threads. Maybe an aftermarket replacement axle. As to the rear wheel hub, some hubs were shaped like that. I have one on my Runabout.
csnailnrun
First Name: Ryan
Last Name: Snellen
Post by csnailnrun » Fri Feb 09, 2024 9:34 pm
You’re right Jerry! Brian fart on my end 😝 I’ve never seen this design before on the hub. Just curious to see the feedback from the group.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Feb 09, 2024 10:10 pm
Looks like a Che^rolet hub.
