Need Photos of body area below RR Door on 24 Touring
SurveyKing
Topic author - Posts: 509
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
If someone would be kind enough to post a couple of photos of the exterior of the body below the passenger side rear door on a 23-25 Touring, I would really appreciate it. We are trying to understand if there was a separation between the quarter panel and the door rocker panel. Thank you
Ruxstel24
- Last Name: Hanlon
Re: Need Photos of body area below RR Door on 24 Touring
I will after dinner, I think there's a seam there.
- Last Name: Strange
- Board Member Since: 2013
Here is that area on my 1925 Touring body. There is a seam, the parts are attached to the wood rail with four round head wood screws. I only have two screws installed on the picture because I can't reach the lower two with the body near the floor of my basement.
I have been told that this area is hidden below the rear fender on a finished car.
I may be mistaken but I think the Tourings from 17-25 have that seam.
RustyFords
- First Name: Don
- Last Name: Allen
SurveyKing
- Last Name: Snell
It appears as though the seam was intentional as the pieces were stamped originally separately. Was that the method originally used, screwing the pieces together into the wood frame? Interested to see if anyone has any other photos they could post for clarification.
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
some changes but all had a seam 14-25. charley
Ruxstel24
- Last Name: Hanlon
Seam on mine, don't see any screws...
RustyFords
- First Name: Don
- Last Name: Allen
My car saw a lot of farm repairs back in the day.
I wouldn’t be surprised if that screw was one of them...although it does have the exact same screw in the exact same spot on the other side
1924 Touring
SurveyKing
- Last Name: Snell
Mark Strange, could you post a pic of the passenger side of the rear door as well? Thanks
Sure, here it is. I didn't take a picture of the passenger side before because it looks just like a mirror image of the driver's side.
