timing with a 270 regrind cam
mike37 cdn
Topic author - Posts: 28
- First Name: mike
- Last Name: mclean
re building my 26 engine bought a 270 regrind cam just wondering if I need to set the timing different than the stock at 15 dec atdc i put in new ss valves and adjustable lifters and running high compression pistons thanks mike
Re: timing with a 270 regrind cam
Same as any other T, just after top dead center. You are setting for the spark to happen just after to prevent kick back. After that setting to where it runs best.
