How to install Rocky Mountain Brake linings
bmklawt
First Name: Bruce
Last Name: Klawiter
Post by bmklawt » Sat Mar 30, 2024 12:59 pm
This may have been discuses before but I can't find it.
Getting ready to install Rocky Mountain Brakes on my 27 Touring but first I need to put on new linings, is there a certain procedure I should follow to do this, to me it looks like I just start at one end and finish on the other, centering the lining on the band.
Your help is greatly appreciated,
Bruce
Re: How to install Rocky Mountain Brake linings
Post by TRDxB2 » Sat Mar 30, 2024 1:38 pm
instructions for adding the brakes
T-2565-B Rocky Instructions.pdf
(388.9 KiB) Downloaded 99 times
instructions for the Brake Equalizer
T2565XS-5833.pdf
(183.93 KiB) Downloaded 78 times
discussions on the linings
viewtopic.php?t=9253
:idea: https://www.mtfca.com/discus/messages/1 ... 1279998740
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Sat Mar 30, 2024 1:52 pm
When I reline Rockies I clamp the band and lining to a drum, squeezing it together like they would when operating. After aligning the band and lining I drill all the holes. Disassemble, countersink the holes and the rivet lining to the band from the middle out.
Andy
