Coil rebuil capacitor fit question
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Sun Apr 07, 2024 3:32 pm
I decided to try and rebuild a few coils. The new capacitors I received from Langs are cylindrical and do not fit in with the glass plate. Do I remove the glass plate with this newer style cap?
NealW
First Name: Neal
Last Name: Willford
Re: Coil rebuil capacitor fit question
Post by NealW » Sun Apr 07, 2024 3:41 pm
I did when I used the round capacitors to rebuild coils.
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Sun Apr 07, 2024 4:07 pm
Ron Patterson
Post by Ron Patterson » Sun Apr 07, 2024 4:11 pm
This assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
There are two ways to install them: one is to remove the glass separator to make room for the cacpacitor OR; if you prefer, remove the glass separator AND the two wooden blocks between the glass separator and the secondary winding, after installing the capacitor reinstall the glass sedparator in the area previously occupied by the wood blocks.
Regardless which way you go, always repot the coil with tar to firmly hold the new internal parts/wiring from moving.
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Sun Apr 07, 2024 4:35 pm
Coil Resistance Readings 001.jpgThis assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
Thank you Ron! Much appreciated.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Mon Apr 08, 2024 6:13 am
I have found that it is easiest to carefully remove the left side of the coil to gain access and remove the old glass and capacitor.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Apr 08, 2024 7:31 am
And after your connections are checked , and the side is replaced, hot tar will keep everything in position including the wood side you replaced , no glue needed on the wood.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 08, 2024 10:41 am
I have been running coils that I installed ignition “condensers” from’60’s era design Ford cars for at least 40 years. I removed the glass to get room and never “repotted” with tar ( some RTV yes). They work great and I have had them recently tested and they test great.
Just saying!
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Apr 14, 2024 3:11 pm
Rebuilding those coils is what the British call penny wise and pound foolish!
Been there and done that!
This #3 tar barrel cost $95 about 25 years ago, I hate to ask the price now.
TarBarrel Small.JPG (18.17 KiB) Viewed 2459 times
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Apr 14, 2024 4:21 pm
Why aren't the oval style no longer made. Is there something inherently wrong with them.
Art Mirtes
Moxie26
Post by Moxie26 » Mon Apr 15, 2024 4:49 pm
Hi Art ..... I'm not sure who made those capacitors, or even if they're still in business that I noticed also that they're not available. The ones that I installed in coil rebuilds as far as I know or still working because I haven't had any complaints.
