McLaren wire wheel nut torque.
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Tue Apr 23, 2024 7:33 pm
I'm concerned about my new Mclaren wheel nuts coming loose as there is no taper or no lock washer. Anyone with experience with these wheels?
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Re: McLaren wire wheel nut torque.
Post by flatbroke3 » Tue Apr 23, 2024 8:48 pm
I used longer bolts so I could use a lock washers.
Harold III
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Wed Apr 24, 2024 3:09 am
35 ft-lb - never had a problem with wheel nuts.
Respectfully Submitted,
Be_Zero_Be
Post by Jerry VanOoteghem » Wed Apr 24, 2024 10:04 am
Apparently nobody has had any issues with these, but if it were my car, I would never use the brass acorn nuts to hold wheels on.
mlandry
First Name: Michael
Last Name: Landry
Post by mlandry » Wed Apr 24, 2024 10:37 am
I have had McLaren wheels on my 14 touring for 20 years. We have been on many long tours. Never a problem with nuts loosening. However, make sure to check your hubcaps regularly. I have lost 2 hubcaps. One came off with a bang somewhere near Savannah, Georgia. The other one disappeared quietly on a tour stop in Gettysburg, Pennsylvania. Maybe fell off, maybe only hand tight and taken as a souvenir by an admirer. They came off different hubs. Now, I make sure that they are tight before any tour, good time to check nuts as well. A tiny bit of permatex on the new hubcaps has kept them tight.
Enjoy your wheels. My wife thinks the ride is much improved, and I agree.
