quick bolt set for model A & T Ford
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat May 18, 2024 8:02 pm
i have made another run of "Quick Bolts " for fitting the mainbearings in Models A and T Ford ( 4 sets ) ... these are made from mild steel bolt stock as the originals ... the quick bolt reduces the time and labor in fitting the mains by reducing the time needed to remove and tighten the original bolts ...set includes the 6 bolts , nuts and forked keepers ... price of $150 plus $15.00 postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ... Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Re: quick bolt set for model A & T Ford
Post by Gene_French » Sat Jun 15, 2024 10:16 am
to the top again , thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jul 13, 2024 9:09 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Aug 04, 2024 9:13 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Aug 29, 2024 9:24 am
to the top again ... thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 05, 2025 7:36 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Feb 13, 2025 9:19 am
will have quick bolt sets on display at the Duncan<ok. swapmeet in March ... stop in and visit ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Mar 04, 2025 9:40 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun May 18, 2025 2:51 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 23, 2025 9:27 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 30, 2025 10:05 am
