WTB: Original Ford Rear Axle sleeve puller
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Post by michaelb2296 » Thu Jul 04, 2024 1:43 pm
Not looking for modern junk. A real rear axle sleeve puller
Please. Thank you!
Michael
Re: WTB: Original Ford sleeve puller
Post by TRDxB2 » Thu Jul 04, 2024 2:20 pm
Not looking for modern junk. A real sleeve puller
Please. Thank you!
Michael-
Drive shaft spool or rear axle sleeve? Don't have but pictures help
I have a new style rear axle sleeve puller, must be an earlier version, that has a spring behind the button than the newer one doesn't have. Once the button is in the hole in the sleeve it isn't going to slide out.
Drive shaft listed a year ago viewtopic.php?t=34632
drive shaft sleeve puller.jpeg (60.04 KiB) Viewed 2281 times
Rear axle sleeve puller https://www.mtfca.com/discus/messages/8 ... 1258856981
michaelb2296
First Name: Michael
Last Name: Bunner
Re: WTB: Original Ford Rear Axle sleeve puller
Post by michaelb2296 » Thu Jul 04, 2024 5:19 pm
Rear Axle sleeve puller. My mistake for not being clear.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Fri Jul 05, 2024 2:23 am
The Steven's rear axle sleeve remover is the one to get! Highly recommended.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Fri Jul 05, 2024 5:43 am
Thanks for the heads up.
Post by Jerry VanOoteghem » Fri Jul 05, 2024 8:45 am
Does the Stevens tool remove the sleeve while the axle shaft is still in place, or must it be an empty housing?
TrentB
First Name: Trent
Last Name: Boggess
Post by TrentB » Fri Jul 05, 2024 4:33 pm
The Stevens rear axle sleeve puller is hollow in the center, so it can be used with the axle shafts still in place.
Post by Allan » Fri Jul 05, 2024 8:04 pm
The one Dave Huson posted is the ducks guts. You can use it with the axle still in the housing. The hose clip shown is a later addition, probably to make up for the loss of the spring used to hold the little register in the sleeve hole. I don't have one, nor do have the TT one I passed on a few years back!
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Tue Jul 16, 2024 5:46 pm
Still looking
Last Name: Hatch
Post by Dan Hatch » Tue Jul 16, 2024 6:19 pm
Scott Conger reproduced some a few years ago and they are great. He said he would not do it again, but maybe if you ask real nice he might be talked into it. Dan
Last Name: House
Post by George House » Tue Jul 16, 2024 6:50 pm
I have an original dealership type rear axle sleeve puller I’d sell. Let me go out to the barn and take a picture of it.
Last Name: House
Post by George House » Tue Jul 16, 2024 7:09 pm
Here it is Michael. If this is what you’re looking for, email me. I’ve used it over half a century, its heavy duty and in good shape. Can also be used when axle is in the housing.
T Rear Axle bearing sleeve puller
Last Name: House
Post by George House » Thu Jul 18, 2024 5:00 pm
SOLD to Michael. Thank you sir and thanks MTFCA 😀
