Tire Tube Stem Covers F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun Jul 14, 2024 3:31 pm
These are made of brass, nickel plated, now covered with "patina", $45 set of 4 including domestic postage.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Tire Tube Stem Covers F/S
Post by Humblej » Mon Jul 15, 2024 6:52 am
Those are Dill valve covers. Dill is one of the several suppliers to Ford for valve covers. What makes these valve covers special is they screw onto the top of the valve stem in place of the little valve cap so they can be used with a modern rubber stem inner tube.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Thu Jul 25, 2024 11:24 pm
To the top!
Post by Allan » Fri Jul 26, 2024 1:23 am
They are also brass. They would look really nice with the nickel plating removed and the stems polished.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Fri Jul 26, 2024 6:36 am
Recently bought a nice set of Dill nickel-plated stem covers from Layden. The other neat thing about these Dill covers is once you have them threaded onto your tube stem and in position you tighten them down and they will lock into that position. They look great on one of my nickel era cars.
bryan831daniel
First Name: Bryan
Last Name: Daniel
* REQUIRED* Type and Year of Model Ts owned: 1913, 1914, 1919, 1920, 1921, 1923, 1924, 1926, 1927
Post by bryan831daniel » Fri Jul 26, 2024 7:01 am
I’d like them. Message sent. ~Bryan
