WTB Used Warford
Jerry Young
First Name: Jerry M
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring1927
WTB Used Warford
Post by Jerry Young » Fri Dec 27, 2024 12:20 pm
WTB used Warford transmission for Model T, please respond with condition and price. Thanks
Jerry
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: WTB Used Warford
Post by Dan McEachern » Fri Dec 27, 2024 12:58 pm
There are three different Warford tranmissions. Aluminum case two speed, aluminum case 3 speed and the cast iron 3 speed that requires a rear cross member and a front u joint. You should probably specify which one you are looking for.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Fri Dec 27, 2024 1:58 pm
Jerry I have a ton of warford parts if you end up needing some no whole boxes at the moment
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Fri Dec 27, 2024 2:44 pm
Sorry, I need a 3 speed cast iron unit, have front u joint and support, anyone have something? Karl, you have enough stuff to assemble one?
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Fri Dec 27, 2024 6:02 pm
I had a 3 spd cast iron unit that was in great shape, complete with rear frame bracket, shifter, and copy of the original installation instructions for the TT. It went away with my TT (never installed) when I sold it 6 yrs ago.
I'm actually going to see the guy I sold it to this weekend, I'll ask him his intentions and if interested in selling. Will let ya know Sun or Mon. I also had a spare TT torque tube & driveshaft to cut.
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Fri Dec 27, 2024 7:20 pm
Will a Warford for a TT fit a T? I would consider a 3 speed aluminum unit as well as the cast iron unit.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Fri Dec 27, 2024 7:57 pm
As I understood it from period info, the aluminum case tranny's were built for the auto's, while the cast iron case was built specifically for the TT being a much heavier/stronger unit. I imagine the tranny itself however can be used in a car given there is no difference in how it connects...given the tranny connection and ball joint size is no different.
Whether used in a TT or car, the fitment would be exactly the same needing to shorten the torque tube, cut & remachine the driveshaft and shorten the radius rods.
This is all conjecture on my part, but I can't visualize any connection difference. The only thing unknown to me are the specs between the two, eg, case length, and how that could affect differences in cut lengths. I also do not know if there are differences in gear ratios between alum & iron case trannys. Hopefully others who have installed a cast iron case in a car will chime in.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Dec 27, 2024 9:28 pm
I dont I have like 80% mainly need a good cluster I don't have any that arnt trashy
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Sun Dec 29, 2024 5:37 pm
Update, the guy I sold my TT has already gone thru the tranny and intends to install it in the truck....sorry.
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Tue Dec 31, 2024 8:47 am
No problem, thank you for checking. Jerry
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Tue Dec 31, 2024 10:23 am
Hey Jerry, no problem, sorry it didn't work out. But, if you do end up getting a hvy dty Warford 6, I was able to retrieve the original Warford hvy dty 6 (TT) instructions I had (but had passed on to the new owner) that may be of interest to you. I'm gonna reprint it for anyone interested.
See my post were I posted pics of the brochure.
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Post by YellowTRacer » Tue Dec 31, 2024 6:10 pm
I have a cast iron warford. $100.00 plus shipping. It's heavy.
Ed aka #4
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Thu Jan 02, 2025 2:13 pm
Es. what is the condition of the unit? Do you know what the shipping to 76028 might be?
Jerry
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Thu Jan 02, 2025 2:14 pm
Dang spell check! Ed not Es
YellowTRacer
First Name: Ed
Last Name: Archer
Post by YellowTRacer » Fri Jan 03, 2025 4:41 pm
Jerry, I'd like to accomodate you but not sure I'm willing to go through the effort. Probably shouldn't have mentioned my Warford. First thing is relatively easy and that's checking out the condition. It's in storage which is 30 miles away, bridge toll and all, but that aside, I can remove the top and at least tell you what I see. Second part is the problem......shipping that awkward thing. It's heavy, I would probably have to remove the top and maybe have to ship it in a separate box, and I have no idea as to shipping cost without taking it down to a shipper for an estimate, and if shipping is too high then you don't want it, and I've wasted all that time. Unfortunately these days, most of the time I'm way busy and therefore time becomes very valuable. I'm a hobbyist at heart, but there's not enough of me to go around.
Ed aka #4
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jan 03, 2025 6:30 pm
*SOLD (pending payment & pickup). No Longer Available*
I’ve got one that has been disassembled, cleaned, checked, and all the parts are usable. It has fair quality gears. It has been partially assembled with all the needed parts included. I’d sell it as it is for $900. I can do the final assembling and adjustments for an additional $300. The shifter isn’t pictured but would be included. I’d have to pick one out and clean it up. Email if you are interested.
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Fri Jan 03, 2025 9:14 pm
Adam, Is this a 2 speed or 3 speed?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jan 03, 2025 9:43 pm
It is a 3 speed. It has under drive, direct drive, over drive, and a free neutral. Warford called it the “Super Six”.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Fri Jan 03, 2025 11:39 pm
Adam, sent you an email.
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Sun Jan 05, 2025 5:19 pm
Just to be clear, I am not hung up on a cast iron unit, I would consider an aluminum unit.
OGTim13
Last Name: OGorman
* REQUIRED* Type and Year of Model Ts owned: 22 Touring and 23 Runabout
Post by OGTim13 » Sun Jan 05, 2025 11:41 pm
Jerry I have two Warfords for sale if you want I can send pictures.
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Mon Jan 06, 2025 8:56 pm
Tim, yes please send pictures via PM or email.
Jerry Young
First Name: Jerry M
Last Name: Young
Post by Jerry Young » Sun Jan 26, 2025 10:53 am
Thanks to all who responded to my search for a Warford, I have found one and no longer need one.
Thank y'all
Jerry
