Fender mounting hardware
browning
First Name: David
Last Name: Kahle
* REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
Post by browning » Thu Jan 23, 2025 4:32 pm
I am considering replacing the fenders etc. on my 1919 Roadster with new and hate to strip the mounting hardware from the existing parts since they are in pretty good shape (no rust) and could be used by others if unmolested. Is there a place where replacement mounting hardware can be purchased, new or used. I don't think I have ever seen it advertised.
Re: Fender mounting hardware
Post by John kuehn » Thu Jan 23, 2025 6:46 pm
Did you mean the fender brackets? If you did I don’t think the new T fenders that are available have the fender mounting brackets that are rivited on.
Since they don’t have the brackets you will need to remove your old ones and remount them on the new fenders. That’s what T owners do when they buy a new fender.
And yes no one reproduces the fender brackets. Or at least they didn’t use to. Just because they are rusted up people will buy the brackets. In some places they are hard to come by.
Post by TRDxB2 » Thu Jan 23, 2025 6:49 pm
no repro's except for brass-era
eBay, forum, Facebook for parts or used trash fenders
Could find someone to trade
Red circled hard to find
Yellow circled much easier
Post by speedytinc » Thu Jan 23, 2025 6:51 pm
Put in a WTB for fender mounting brackets.
Parts sellers have junkie fenders that are only good for the mounting plates.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Thu Jan 23, 2025 7:10 pm
FYI, Sacramento Vintage Ford has them for the 13-16 fenders. They're backordered at present, but they told me they should have them in 2-3 weeks. Noel
Post by John kuehn » Thu Jan 23, 2025 8:33 pm
You might call Lang’s. They have a supply of good and NOS T parts. The top fender brackets are the same for L and R. But the corner brackets aren’t. They have to be L or R.
Post by Allan » Fri Jan 24, 2025 5:11 am
The top fender brackets with which I am familiar are left and right. The mounting holes in the fenders may be the same pattern, but one of the brackets would need to be rotated to align with the holes, putting the mounting slot either in front or behind the frame iron.
