20's differential in 1913 rear axle housings?
MMorse
Last Name: Morse
* REQUIRED* Type and Year of Model Ts owned: 1924 tudor sedan
Post by MMorse » Wed Apr 09, 2025 7:03 pm
Good evening. The subject pretty much sums it up. I've got a 1913 rear axle with very worn parts, including the spider and spider gear bushings (yes, bushings). Would the guts (differential) from an early 1920's rear axle fit into the 1913 housing without any fitment issues?
Thank you!
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: 20's differential in 1913 rear axle housings?
Post by Dan McEachern » Wed Apr 09, 2025 7:36 pm
yes, everything will fit the same as the earlier parts.
MMorse
Last Name: Morse
Post by MMorse » Wed Apr 09, 2025 8:47 pm
Okay, thanks. That’s what I understood but was second guessing myself. I appreciate your help.
Last Name: Hatch
Post by Dan Hatch » Thu Apr 10, 2025 8:51 am
That is the beauty of a Model T. Most mechanical parts are interchangeable between the years. It was planned that way.
