WTB APCO spring loaded accessory located - thanks everyone - thanks MTFCA
Post by Scott_Conger » Fri Apr 18, 2025 4:34 pm
I suspect that the supplier is no longer reproducing this part, as no supplier has them in stock any more. The APCO part for the radius rod is still available, but the one that fastens the radius rod to the pan is not...
I'd like to purchase a new or original part to help my dad bring his "shimmy" under control. He has a friend who will be going over the front end and has found numerous things to correct and this is one of them (but is the only part that I cannot find through the normal supply chain).
If you have one kicking around and want it to go to a worthy project, I'd sure be interested to hear from you.
thank you
Re: WTB APCO spring loaded accessory - radius rod to pan
Post by Scott_Conger » Sun Apr 20, 2025 9:34 am
Really need to find one of these for my dad...
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Apr 20, 2025 10:11 am
I have one
Post by Scott_Conger » Sun Apr 20, 2025 10:38 am
Ed
sent you and email
thank you very much
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Apr 20, 2025 1:09 pm
PM sent to you.
