Compression test. Starter vs crank
bobt
Topic author - Posts: 301
- First Name: Robert
- Last Name: Thompson
Has anyone done a cylinder compression test recording electric starter vs crank psi? I'm losing my strength and find it hard to get over TDC even with the other plugs removed.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Re: Compression test. Starter vs crank
Jack up one wheel.
I believe you'd get good results using a starter. Most compression tests are done using a starter. Unless the compression is very low in all cylinders, you're looking for significantly different readings from cylinder to cylinder as much as for the peak pressure. I'd expect that testing each cylinder on the starter with the other 3 plugs still in place would give results very similar to a brisk manual cranking with the other 3 plugs out.
Just did a '15 yesterday - hand cranked, jacked up, plugs out & throttle wide open - I'm hitting 70 so I'm starting to feel it too !
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
When hand cranking have to spin the engine several revolutions to get a reading anywhere close to a starter. Starter should get you 50-60psi, pulling over 1/4 turn by hand will show bout 35, spinning by hand probably bout 45-50.
That's in the ballpark of my readings, Kevin !
AndyClary
- First Name: Andrew
- Last Name: Clary
Unless the reading is real low don’t get too fixated on the actual number. As Pat brought up you are looking for consistency between the cylinders.
Andy
Andy
John Codman
- Last Name: Codman
I don't know what type of compression tester you are using - mine is a hold-in, I'm guessing that yours is a screw in. If so, just install the tester and crank it over with the starter. If yours is a hold-in, you will need a second person anyway. A remote starter switch won't work on a T because there's no starter relay and the remote starter switch would melt down almost instantly if you run full 6V starter current through it.
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
So far, no one has mentioned a “dry test” vs. a “wet test”.
Dry is “as is”, for a wet test, squirt a little oil into the cylinder through the plug hole. Wet/dry variation can tell you something about the condition of your rings. From my experience, a “hold in” gauge is practically useless when checking out a model T.
Get a horse !
