FS Stewart speedo gears
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Mon Aug 25, 2025 10:52 am
Stewart speedometer gear see pics for condition 40$ ea plus the ride
Re: FS Stewart speedo gears
Post by Allan » Mon Aug 25, 2025 9:25 pm
Interesting gear with no spokes Karl. The block printing is early, as is the four hole mounting drilled into the bosses on the casting. Then it has also been drilled for a second four hole mounting. Using the lower right of these holes, two more have been drilled to make a three hole mounting like the later gears.
Allan from down under
