WTB: Watts Clutch Pack
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Wed Sep 03, 2025 11:13 pm
Do you have a Watts Clutch Pac laying around you want to turn it into CASH!!!! I'm looking for same.
thnx
frontyboyText or call 2ho6 919 1949
Dale_mcm
First Name: Dale
Last Name: McMurry
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
Re: WTB: Watts Clutch Pack
Post by Dale_mcm » Thu Sep 04, 2025 12:12 am
I Have one.
Dale McMurry
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Thu Sep 04, 2025 11:15 am
Dale,
Good to hear from you!! Tell me about your Watts Clutch, new used ?? and of course how much, photos.
Frontyboy
Dale_mcm
First Name: Dale
Last Name: McMurry
Post by Dale_mcm » Sat Sep 06, 2025 12:34 am
Bought 2 clutch packs from R V Anderson and put one into 1910 engine. Only ran this engine on test stand, but had flywheel problem, so I
disassembled engine. Price is 75.00 plus shipping. I used clutch spring on something else.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Sep 06, 2025 2:34 pm
Is the Watts Clutch Pack different than the Jack Rabbit Clutch Pack than Snyders sells now?
Dale_mcm
First Name: Dale
Last Name: McMurry
Post by Dale_mcm » Mon Sep 08, 2025 12:43 am
Howard, please be aware that the pack I have is for 09-25 drums, not 26-27. Let me know.
Post by DanTreace » Mon Sep 08, 2025 1:43 pm
Yes, main difference is the Watts replaces the Large discs, with fiber cutouts running on the brake drum lugs.
The Turbo 400 or "Jack Rabbit" replaces the Small discs are modified by trimming off some of the metal tabs of modern 400 auto trans discs. The metal tabs running on the clutch drum recesses.
Types of modern discs.jpeg (95.25 KiB) Viewed 683 times
The Watts can fail as the fiber cut outs could shear if a disc hangs up on rough brake drum lugs.
Failed watts clutch disc sheared.jpg (109.26 KiB) Viewed 683 times
There was another style of Turbo 400 sold by Lang's, these are std. 400 auto trans discs with all the lugs, but has to be used with a special cast clutch drum with multiple notches to mate with the disc. The Special drum isn't available as far as I know.
Langs sold Turbo 400 version with hub.jpeg (80.48 KiB) Viewed 683 times
Last Name: Hatch
Post by Dan Hatch » Mon Sep 08, 2025 1:50 pm
Someone was making a stock replacement clutch drum. Wish he would make the 400 drum. That is what is needed. I got a 55 gallon drum of stock drums.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Sep 09, 2025 1:27 am
The last pic I seen of the Jackrabbit clutch discs they looked like the Turbo 400s but still had the full square lugs.
