What's this bolt for?
Thorlick
First Name: Terry
Last Name: Horlick
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
Post by Thorlick » Fri Jul 05, 2019 4:44 pm
I was just searching through my spare parts for some needed bits and found this part.
Here is a normal water inlet I found:
Here is the one I think is unusual.
It has a bump on the inside, the hole is not drilled through.
It has a bolt with what looks like a conduit clamp.
The only thing I can think of is a clamp for the horn wire, what's your guess? Have you ever seen one like this?
TH
Re: What's this bolt for?
Post by Rich Eagle » Fri Jul 05, 2019 5:00 pm
Model A's used a bolt there for the generator conduit. Could that be for a Model A?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Jul 05, 2019 5:38 pm
Rich is right, Model A Ford.
Thorlick
First Name: Terry
Last Name: Horlick
Post by Thorlick » Fri Jul 05, 2019 6:01 pm
Thanks, I thought I had some sort of rare, unusual aftermarket T part. Instead it is a relatively worthless part from a gooney little known car!
(tongue firmly in cheek)TH
Post by Wayne Sheldon » Sat Jul 06, 2019 4:36 am
I am pretty sure I have one of those in my junk boxes if you need another?
Thorlick
First Name: Terry
Last Name: Horlick
Post by Thorlick » Sat Jul 06, 2019 11:38 am
Thanks, Wayne, but I don’t wear ear rings!
TH
