23 inch 5 lug demonstrable rims
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Sat Nov 15, 2025 7:05 pm
I just picked up some Model T parts and there were 4 23 inch rims but they have 5 lugs. One of the rims has a Buffalo Cord Dunlop 31X4 smooth tire on it. Are these for Model T rims? All the Model t wheels i have are 4 lug
Re: 23 inch 5 lug demonstrable rims
Post by Wayne Sheldon » Sat Nov 15, 2025 8:50 pm
Possible that they could have been for after-market wheels for a model T. Or not.
You say "smooth" tire? Do you mean worn to treadless? Or smooth never had a tread (common on tires before 1920)? Or smooth (straight?) sided tire as in not a clincher?
Are the five lugs fixed (attached?) to the rim?
Post by RajoRacer » Sat Nov 15, 2025 8:50 pm
There were several accessory demountable wheel manufactures before Ford got into the game.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Nov 15, 2025 10:19 pm
Accessory Firestone wood felloe demountable wheels and pretty sure the Atlas steel spoke wheels had 5 lug demountable rims… but don’t believe either had lugs fixt to the rims. Interesting…
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Sun Nov 16, 2025 7:11 am
A little more information.
Lugs are attached to the rim.
4 are closed one is open slotted.
Cleaned up one lug is Marked Hayes
Post by DanTreace » Sun Nov 16, 2025 9:03 am
Photos show those 5 lug rims to be for straight sided tires, as they are 'split rims'.
Likely for a larger car with wood demountable wheels.
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Sun Nov 16, 2025 9:24 am
Thanks great information .
Post by Allan » Sun Nov 16, 2025 8:44 pm
Definitely not for T models, on two counts. Ford always used four lug rims. Secondly, the only split rims Ford did use were 21' rims on the 26-7 cars.
