Timing mark
big2bird
Topic author - Posts: 729
- First Name: Jeffrey
- Last Name: Hausey
Timing mark
Has anyone ever set up a pointer/ mark on a T motor for TDC? Just asking, since I use a Bosch front plate.
- Last Name: Hjortnaes
Re: Timing mark
It has been done at the Speedster Reunion to get dynometer readings, so it should work for you.
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Re: Timing mark
I just use a fine line paint pin and put a mark on the back of the pulley and the timing cover.
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Timing mark
If you have an aluminum pulley you can use the split for a timing mark. On stock pulleys on run the paint marks around the back a little away from the belt.
Andy
Andy
