1927 Howe TT Fire Truck SOLD.
Bob in Texas
Topic author - Posts: 46
- First Name: Bobby
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
1927 Howe Fire Truck. TT Chassis. Runs, Drives, Stops as should. 3 cylinder positive displacement pump. No idea id pump works but externally everything operates as should. Discharge and suction valves need rebuilt. New front tires. New Kevlar transmission bands. Spot light and siren work. Hose reel in picture included but not mounted. NOT INCLUDED: Bell, Lanterns, tool box. Located near Houston, Texas $17,000
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
Re: 1927 Howe TT Fire Truck
Does this truck have have any kind of auxiliary transmission, or "high speed" axle gears?
Bob in Texas
- First Name: Bobby
- Last Name: Wright
The rear axle is high speed rear end.
The transfer case has a low speed drive output with pu.p NOT in gear. Works like a Rux.
Big improvement... maybe 30 MPH?
Bob in Texas
- First Name: Bobby
- Last Name: Wright
I have never clocked it but I am sure yes.
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
According to Brent Burger in Spokane,
Pat, you sound pretty interested, I think that you should buy this one.
Keep crankin',
Eric
He puts a lot of miles on his TT Flatbed in Eastern Washington. The Fire Truck is undoubtably heavier, but the flat ground cruising speed should be close.Burger in Spokane wrote: ↑Mon Jun 24, 2019 10:48 amPutting Henry's comment into perspective, a 7:1 ratio gear set will have your engine
maxed at 20mph. Even slower if it is not rebuilt and balanced. A rebuilt and balanced
engine with a 5:1 gear set will do a comfortable 35 and have an upper end approaching
50...
Keep crankin',
Eric
Send money..... !! (And indoor storage space!)
Bob in Texas
- First Name: Bobby
- Last Name: Wright
Truck sold
