I am assembling a 26 transmission. Have on hand a good driving plate with the exception of some scouring on the ball cap / 4th main contact area. I have a crankshaft grinder so it isn’t a huge job to turn the bearing contact area underside.
Which will mean an increase in the Babbitt thickness in the ball cap.
I estimate the diameter will be about .035” undersized.
Wondering if any engine builders have tried this?
26 - 27 rebuild 4th main babbitt thickness
- Last Name: van Ekeren
Re: 26 - 27 rebuild 4th main babbitt thickness
Do it all the time, machine the drive plate and increasing the thickness of the babbitt and re-machine that to fit, the early ball caps made by dodge had about 1/4" thick babbitt.
- Last Name: Hatch
Here is a link to a thread from Herm. Shows how he did a transmission. Look down at how to fix your problem.
https://www.mtfca.com/discus/messages/3 ... 1375578307.
These post should be saved for new guys. Dan
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Dave:
the reduced diameter on the driveplate and thicker babbitt in ball cap should not be a problem ... i have seen drive plates ground to 1.500" diameter and there is a variety of ballcap types with babbitt lining from probably .030" per side to around 1/4" per side ... i believe the 1.500" was to fit a ball bearing ball cap ...gene french
