Need to make parts for a manifold heater
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sat Jan 24, 2026 9:15 pm
I just bought a really nice manifold heater. It is straight as a die and the exhaust pipe threads are perfect. The screws holding the tins on came right out. It did not come with the parts that go in the floorboard so I have to find or make them. I have looked at different ones in the forum and other places and I don’t see one quite like this. It has a very small outlet that does not seem to be like those others I have seen. I can’t figure out how it would connect to the vent in the floor. Any hints?
I do have the sheet metal cover, just not on in the shot.
Re: Need to make parts for a manifold heater
Post by speedytinc » Sat Jan 24, 2026 9:39 pm
Looks like someone added a shield for the F/W. The normal heat pickup covers all those finns.
Keep looking for examples & the design will be come obvious.
Post by RajoRacer » Sat Jan 24, 2026 9:43 pm
I'll get some photos of mine for you. I also have an extra floor register.
Post by TRDxB2 » Sat Jan 24, 2026 10:01 pm
From an old post
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat Jan 24, 2026 11:01 pm
I saw the old post and mine is like the top example. I have all the tins, I just took them off to check it out and clean out the wasp nest. But, as I said, it does not match the drawing.
Post by RajoRacer » Sun Jan 25, 2026 11:07 am
There were several manufacturers of those types of heaters - the silver shroud one is on our'19 Centerdoor - photos coming.
Post by DanTreace » Sun Jan 25, 2026 11:27 am
Some pics of registers for those heaters.
Floor board install
Have one of these registers in my stash if you need one, may be useful for your install.
Post by TXGOAT2 » Sun Jan 25, 2026 2:45 pm
Looks like a prolific source of squeaks. I wonder if a flex coupling for the register could be made from the material they make oven door gaskets from. (?)
Post by RajoRacer » Sun Jan 25, 2026 4:18 pm
Like you could actually hear a "squeak" over the engine noise & knarly planetary ?
Post by TXGOAT2 » Sun Jan 25, 2026 4:29 pm
You could in my car.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Jan 26, 2026 9:25 am
Rich Eagle made a vent for his heater. See the posts starting around Feb 8.
https://mtfca.com/phpBB3/viewtopic.php?t=371
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Jan 27, 2026 9:33 pm
Thanks guys. I got a register on the way in the post. I will clean things up and get the manifold ready to go on the 22 in the spring. I have a Z head to go on it and a few other things to do when the weather gets better. I have a zenith carb and intake I might try as well. My 22 is a rolling accessory magnet.
