Cowl Lacing
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Cowl Lacing
Post by GG Gregory » Sun Aug 04, 2019 1:38 pm
How's the best way to install new Cowl Lacing on a 27 Roadster ? The old lacing was held in place with small ring shank nails through tiny new holes made into the Cowl....yes I know that's not the correct way. I'm lost at how to keep the lacing lined up and drilling the hole through it for rivets.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Cowl Lacing
Post by Humblej » Sun Aug 04, 2019 1:50 pm
If I remember right it is held in place by spiral shank nails.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Cowl Lacing
Post by Jim Sims » Sun Aug 04, 2019 1:57 pm
Should be held on with split rivets. The heads are inside the cowl and the split part is outside. Almost impossible to install with the gas tank in place.
GG Gregory
First Name: GG
Last Name: Gregory
Re: Cowl Lacing
Post by GG Gregory » Sun Aug 04, 2019 1:59 pm
The gas tank is out.
GG Gregory
First Name: GG
Last Name: Gregory
Re: Cowl Lacing
Post by GG Gregory » Mon Aug 05, 2019 3:49 pm
Thanks for all the replies...it sure helped. :twisted:
