26 Coupe Steering Column
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by dunoon » Fri Aug 09, 2019 2:22 pm
Is there suppose to be any kind of rubber/cushion between the steering column and dash board?
Ruxstel24
Last Name: Hanlon
Re: 26 Coupe Steering Column
Post by Ruxstel24 » Fri Aug 09, 2019 2:54 pm
I believe it should be a strip of leather.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Aug 09, 2019 3:26 pm
Yes, molded rubber u shaped pad, one above and one below the steering column.
