.10 over pistons Question
lorenzo26
First Name: lorenzo
Last Name: leon
* REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
Post by lorenzo26 » Thu Sep 12, 2019 8:37 pm
Do they make .10 over pistons for a model t engine ?
Last Name: van Ekeren
Re: .10 over pistons Question
Post by Kerry » Fri Sep 13, 2019 3:12 am
No, if you still have a std bore I doubt a .010" re-bore would clean it up, I've even had to take std's up to .060" at times to get a good finish.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Fri Sep 13, 2019 3:33 am
Get a set of .030 pistons and have a competent machine shop bore and hone it. These blocks can go .060” and beyond. If you are worried about the longevity of a block that is .010” oversized at 90 years old you must be expecting to live to be 400.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Sep 13, 2019 7:23 am
Lorenzo, as you know the usual vendors only go up to .08, but if I remember some prevoius discussions, there may be more size options if you contact the manufacturers directly. Egge is one.
lorenzo26
First Name: lorenzo
Last Name: leon
Post by lorenzo26 » Fri Sep 13, 2019 8:48 am
i will call them thank u all for input Lorenzo
