Another what is it?
70shovelhead
Topic author - Posts: 85
- First Name: Preston
- Last Name: Wells
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
- Board Member Since: 2008
Another what is it?
Fella had this laying on the table at an antique engine show I am at this weekend. Anyone want to guess what it is.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
- Last Name: Juhl
Re: Another what is it?
Spring separator - lets you lube between leaf springs.
70shovelhead
- Last Name: Wells
The gentleman is asking $50 for it. A little high I believe. He says Ford made one with script. Is that a fair price?
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
The handle section is supposed to screw off the blade. It is filled with grease, and when screwed back onto the handle, the grease is forced through the shaft and out the little slot in the blade, thus lubricating the spring at the same time. I have one just like it, with the brand cast into the handle. It is not a Ford part. It could well have preceded automotive work.
- First Name: Dennis
- Last Name: Seth
I think $50 is high priced but then again I drive Model T's !
I've got nearly every Ford Z tool and that was not one of them.
Allan is correct in it's use, and it was called a Tomahawk spring lubricator. I have one and it works far better in theory than in practice.
http://www.mtfca.com/discus/messages/118802/122431.html
- First Name: Henry
- Last Name: Lee
I really think Scott needs to buy this since he is deep into real cowboy country. When dim dar Ingins coming a runnin, there ain’t going to be no razor burns when he gets scalped. Just pull it out and say, “use this one”!
Hank, yep, and if it's just a near-miss, they can leave a bit of grease for that period sporty look!
- First Name: Henry
- Last Name: Lee
Yep! Just Going Get fuzz from me!!
