Cracked Clutch Plates
got10carz
Topic author - Posts: 602
- Last Name: Meixner
I've taken apart alot of transmissions, but I dont remember ever finding this many cracked discs. Can't imagine the heat it took to do this.
- First Name: Henry
- Last Name: Lee
Re: Cracked Clutch Plates
WOW! Never seen that! Maybe my Dad back in his youth drag racing? LOL
Ruxstel24
- Last Name: Hanlon
Improper adjustment and/or a weak spring, would be my hypothesis.
How torn up is the clutch drum ????
And THAT, Steve, is the $64,000 question, isn't it?
Moxie26
- First Name: Robert
- Last Name: Jablonski
Worn thin, or just cracked ? Running low on oil ?
I've seen lots of them, but not like that.
got10carz
The drum has groves worn, but I've seen worse. Improper adjustment, bad driving skills, and a oil pan with a plug in the top hole all could be factors.
Alan Long
- First Name: Alan
- Last Name: Long
My initial thought on those plates is they are “flexing” in operation going from flat to dished. The cracking appears to be
adjacent to the cut out on the outer plates. As suggested by others a possibility is catching on the drum and not sliding
I’m aware of some rebuilders who intentionally bend one or two plates into a dished form to give a quicker cleaner
disengage into neutral. Alan
